Delyk has a great Twin Peaks PCB that mounts everything to a single board, but turns the enclosure sideways from Rolo's design. I made it fit with top jack, because top jacks :)
Screenprint by PPP
(http://i2.photobucket.com/albums/y44/jpook730/20161004_210001_zpslg0bsmes.jpg)
(http://i2.photobucket.com/albums/y44/jpook730/20161003_200905_zpsq89eoimu.jpg)
It sounds blasted fantastic!
Build notes:
1. I sent PPP the wrong print, and it came out 2.5mm too high. Lesson learned- double check my files. It still fits, but the labels aren't as vertically centered as I like.
2. Screenprint made with the generous contribution of DRolo.
3. To accomplish the same top jack orientation, here's what you need to do:
Mount C8, C3, C4 beneath the PCB in the "crook" of the board-mount pots. C22, C17 must be mini caps, I use Smallbear. I also use Smallbear for the Lumberg jacks and mini stereo jack (wired mono) for the tap out, and small 2 pole power jack.
Once installed, the tap out jack covers the HP, LP trimmers, but those are pretty set and forget anyway.
If you haven't built this circuit yet, do so! It's awesome!
I like the color scheme a lot on that one :)
Quote from: drolo on October 11, 2016, 08:59:50 AM
Thank you!
Man, this is really an incredible circuit. Thank you for making it available, and thank you again for your help with the graphics.
I love it! Amazing job, the colors are really nice.
With the jacks being so close to the circuit board, there's no lfo ticking?
WOW!
That finish is fantastic. I'm gonna have to work on my graphic design skills and submit a couple files for custom finishes like this.
Gongrats on a super cool build!
It looks great! 8) I must finally build my Twin Peaks, love the demos
Quote from: Boba7 on October 11, 2016, 01:54:11 PM
Thanks! No ticking after adjustment.
Quote from: desmondtencents on October 11, 2016, 07:25:56 PM
WOW!
Thank you!
Yeah, I really love the quality of PPP's prints. It's well worth the $25/ enclosure to me. I calculated the time and cost of decals, plus their relative fragility, and screening comes out ahead by a mile.
Quote from: nzCdog on October 11, 2016, 07:44:03 PM
Man, it is so worth it! You should!
