Projects => General Questions => Topic started by: adam_bz on August 20, 2016, 11:58:52 AM
Title: switching question
Post by: adam_bz on August 20, 2016, 11:58:52 AM
Hi.
its probably really simple, but I cant get my head around this for some reason - hopefully someone can help.
Looking at adding a second 3pdt to an enclosure. The first will be the main on and off bypass, the second 3pdt to add in a second effect such as an octave to a fuzz but if you click stomp one it goes directly to off for all rather than just off for effect one.
Hope that makes sense.
Thanks
Title: Re: switching question
Post by: impycat1 on August 20, 2016, 12:31:45 PM
This might help.
http://tagboardeffects.blogspot.co.uk/2012/02/offboard-wiring.html
Post by: jimilee on August 20, 2016, 01:27:22 PM
Stomp one the effect in and out will go to stomp two's main in and out.
Post by: m-Kresol on August 20, 2016, 07:48:14 PM
ok here we go:
*) first main bypass is wired as usual. In/Out Jacks are wired to this stomp
*) However, the effect out (pcb out) of the first pcb goes directly to the second bypass switch
*) second switch is also wired as usual.
*) second switch out (the one usually connected to the out jack) is wired to the free position on switch 1 (the lug generally wired to the pcb out.
