Hello guys im buliding a 5 looper for a friend but i want to put a buffer splitter , one split goes to tuner and the other can be before the first loop or after the 5th loop. and this is the question before of after, please help me.
Thanks
if you're sending something off to a tuner, I guess you want an unaffected signal, so before the first loop?
Yes, i need the signal unaffected, i found in the web a schematic to put a switch to change between the spliter signal bufeered and a signal unbuffered
