Projects => Tech Help - Projects Page => Topic started by: HM on June 21, 2010, 04:37:46 PM
Title: Chunk Chunk - very Treble....
Post by: HM on June 21, 2010, 04:37:46 PM
Hi I did the chunk chunk but I feel the same than with gaussmarkov, they sound very sharp, the treble is very usable.
there is a solution to this pedal sounds better?
anyone would happen?
Title: Re: Chunk Chunk - very Treble....
Post by: madbean on June 21, 2010, 07:54:32 PM
What values have you used for the three tone pots?
Post by: HM on June 21, 2010, 08:36:35 PM
Quote from: madbean on June 21, 2010, 07:54:32 PM
I used all the components listed, the first thing I did was check that, if he had misplaced some capacitors, but no, they are well. in fact the capacitors are not equal in the draft and this goussmarkov? I've seen in other forums also complain of this, and there's a guy that I think a tonestack to correct this problem even I did not, because I wanted to consult with you and the people of this forum.
regards,
