Projects => Build Reports => Topic started by: madbean on June 26, 2011, 09:51:51 PM
Title: Loophole - the lo-fi looper
Post by: madbean on June 26, 2011, 09:51:51 PM
Here's the populated "Loophole" board for the up-coming lo-fi looper. This thing turned out really well. I was able to eliminate some of the noise by selecting the right kind of tone control. There are some noisy settings, but it's very acceptable for a lo-fi application.
Gonna box this one up today or tomorrow. I'll post the completed pic when I can. This thing will fit in a 1590B or 1550B with two 3PDT switches. It'll be tight, but it will be a benefit to have the switches close together due to how it operates (you have to toggle both at once in some cases). 125B will make things a little more roomy...at least there are options depending on the kind of space you want to give it.
[attachment deleted by admin]
Title: Re: Loophole - the lo-fi looper
Post by: jtn191 on June 26, 2011, 10:04:38 PM
mmm... ;D
any chance we'll get a demo? (before I order one anyways)
Post by: jimmybjj on June 26, 2011, 10:07:14 PM
awesome, very excited about this one.
Post by: petesz on June 26, 2011, 11:01:31 PM
 ;D
sounds great, looking forward to this.
Post by: JakeFuzz on June 26, 2011, 11:38:42 PM
Super stoked for this one. This, the clarinot and the Dirtbag delay are next on the list! Just need to get some of these obsolete chips.
Post by: Used666 on June 27, 2011, 03:28:45 AM
In!
Can't wait.  ;D
Post by: stecykmi on June 27, 2011, 04:23:38 AM
cool, does it have a vibrato control?
Post by: madbean on June 27, 2011, 04:47:51 AM
Quote from: stecykmi on June 27, 2011, 04:23:38 AM
No, this doesn't have that. With the Detune mod that's included you can get some vibrato manually.
Post by: night-B on June 27, 2011, 06:55:39 AM
Quote from: Used666 on June 27, 2011, 03:28:45 AM
In!
Can't wait.  ;D
+1
Post by: gtr2 on June 27, 2011, 03:59:03 PM
can't wait to see some demos of this when it's released!
Post by: bigmufffuzzwizz on June 27, 2011, 05:50:41 PM
Sounds promising! I have no idea what this effect is so I'm looking forward to some demo explanations too!
Post by: madbean on June 27, 2011, 11:27:55 PM
Finished product. Works like a charm. A total bitch to wire up in that enclosure so this will probably be a "genius" type project. Anyway, I'll do some kind of demo tomorrow!
(http://www.madbeanpedals.com/builds/images/loophole.jpg)
Post by: irmcdermott on June 27, 2011, 11:33:26 PM
That's awesome. I really don't see me having any need for a pedal like this, but I want one really bad now :)
Post by: jimmybjj on June 28, 2011, 12:28:30 AM
Sweet,  want  ;D
Post by: nzCdog on June 28, 2011, 02:13:33 AM
Epic!  Love to hear a demo, what a cool project :)
Post by: k.rock! on June 28, 2011, 02:24:43 AM
Wow! Great job dude! What's that little switch in the middle for?
Congrats on being able to stuff all that in there man! I'm sure it wasn't easy...
Looking forward to ur demo too ;)
-Kaleb
Post by: mojofilter on June 28, 2011, 02:02:55 PM
awesome! can't wait for this one, and to see what else is coming.
would it be difficult to add an effects loop to it to send the looped part to a different chain of effects and/or amp?
i'm sure others would like to do that as well. it would be cool if you could show how to do it in the build documentation.
Post by: gtr2 on June 28, 2011, 03:55:38 PM
Even though I don't have plans to build this in the near future.  It will be great to see what everyone does with it!!
Post by: madbean on June 28, 2011, 04:06:55 PM
Quote from: mojofilter on June 28, 2011, 02:02:55 PM
Yes, you can insert an effects loop into the recording path. After the input stage, the signal is fed into a dry and record path. The record level is set by a single resistor. By removing that resistor, you can create a send and return, and then the output of whatever is in that effects loop will set the record level. Obviously, you will want to use a bigger enclosure, but I think it could be done with a 125B.
Post by: cjkbug on June 29, 2011, 06:37:07 AM
Quote from: irmcdermott on June 27, 2011, 11:33:26 PM
aint that the truth!
Post by: jtn191 on June 29, 2011, 09:54:23 PM
Quote from: cjkbug on June 29, 2011, 06:37:07 AM
look...
Post by: Used666 on June 30, 2011, 01:41:04 AM
What's the maximum recording time on this?
Post by: gtr2 on June 30, 2011, 01:53:19 AM
Loophole, thats a great name!
Quote from: Used666 on June 30, 2011, 01:41:04 AM
I'm guessing 20 seconds based off the datasheet of the ISD1020A
Josh
Post by: madbean on June 30, 2011, 02:46:31 AM
20 seconds sampled at around 6kHz.
Post by: jtn191 on June 30, 2011, 09:20:08 AM
huh, compared to the lo-fi loop junkie,
recording time is the same, sampling rate on 'Bean's is higher: 2.6 khz vs 6khz
Post by: mojofilter on June 30, 2011, 10:50:28 AM
Quote from: jtn191 on June 30, 2011, 09:20:08 AM
i'm pretty sure a 6khz sampling rate would mean the frequency response goes up to 3khz, which is about the same as the zvex
Post by: jtn191 on June 30, 2011, 11:25:20 AM
agh, duh. you're right
Post by: madbean on July 03, 2011, 10:37:04 PM
The Loophole doc is up!
http://www.madbeanpedals.com/projects/Loophole/Loophole.pdf
Post by: nzCdog on July 03, 2011, 11:32:46 PM
Thanks man... what a cool project! :o 8)
Post by: night-B on July 04, 2011, 08:28:25 AM
That's a tight fit! I think I'll put it in a 1590bb or maybe a 125b if I'm on a good day, my hands are already shaking....
Post by: Used666 on July 04, 2011, 05:19:28 PM
Bought  ;D
Post by: mojofilter on July 04, 2011, 06:31:18 PM
i just ordered one!
the part about adding an effects loop in the build doc was about putting it on the way in to record; i think it would be more useful on playback so you can send the looped part to a different amp and/or effects.
looking at the schematic, i'm wondering if you could take the output from the wiper of the play pot and go back in at the board where you would wire the play pot wiper
would that work?
thanks bean! i'm really excited about this project
Post by: madbean on July 04, 2011, 07:08:33 PM
mojofilter---I believe that will work, too. You could probably have two loops if you wanna go crazy. Pre and post.
I know you guys will come up with lots of cool stuff!
Post by: mojofilter on July 04, 2011, 07:11:25 PM
awesome!
good thing i'm not afraid of big enclosures
Post by: Used666 on July 04, 2011, 08:21:13 PM
I'm going with a 1590BB for mine. I don't want to have to stuff everything in there too tight.
Post by: jtn191 on July 05, 2011, 02:10:31 AM
seems like this might be a cool project to try Jack Orman's relay bypass
