Guys, maybe (probably) it's because it's late and I'm tired, but I can't seem to figure out how to set the trimpot on my Arcadiator. It doesn't seem to be making a huge difference whatever I do. Can someone explain it to me? The rest of the circuit seems to be working properly, as far as I can tell.
Get some sleep and hit up rullywow tomorrow...
Quote from: lincolnic on April 18, 2015, 03:39:59 AM
The trimpot adjusts the threshold for the LFO to activate. This means when you strum your guitar, the LFO will also start at that peak and last a little while. If the threshold is too low, the LFO will be active all the time. If too high, it will never trigger the LFO.
Hope this helps.
Quote from: rullywowr on April 18, 2015, 02:23:31 PM
Hope this helps.
Thanks, that does help. So does that mean I should be trying to set it with the LFO switch on? And if so, does it mean that when I have the LFO on it's never actually going to stay on all the time?
I guess what I'm really asking is, how should I have the knobs/switches set to make it easiest to calibrate? There isn't a lot of info about calibration anywhere, but maybe I'm just missing something obvious.
