Projects => General Questions => Topic started by: Coda-effects on March 25, 2015, 01:45:34 PM
Title: Enclosures
Post by: Coda-effects on March 25, 2015, 01:45:34 PM
Hello !
I am looking for a "special" enclosure. Just a simple enclosure like this one :
(http://i.ebayimg.com/images/a/(KGrHqN,!mEE69UrpGP+BO2D)mo+iQ~~/s-l1600.jpg)
But a lot smaller
Like almost the size of a 1590B... Just a small slopped enclosure
Do you know if I have a chance to find this somewhere ?
Title: Re: Enclosures
Post by: mgwhit on March 25, 2015, 02:17:11 PM
Mac Walker makes a wedge enclosure he sells over on DIYstompboxes.com (http://www.diystompboxes.com/smfforum/index.php?topic=97548), but it's slightly larger than a 125B for all dimensions.
I've never seen a manufactured sloped enclosure smaller than that, but there is a thread around here somewhere where someone chopped a 125B down into a wedge shape.  I suppose you could do it with a 1590B, but at a certain point you're running out of room for your 3PDT lugs.
Post by: Coda-effects on March 25, 2015, 02:52:53 PM
Thanks! But... I know I am difficult-
Hum I found the chopped enclosure :
(http://i1274.photobucket.com/albums/y428/ToneTestedDesigns/camerapics87036.jpg)
But actually I would like to have a flat + a flopped surface because I would like to 3D print a kind of lid.
In order to make a SUPER FUZZ, but at a reasonable size, and with the cool lid to activate it.
I am not sure to be super clear, so I drawed an image
(http://tacticmagic.voila.net/superfuzz.png)
In blue is the enclosure (+ knobs) and in red the 3D print (or another technique) lid to activate the pedal. (with a 3PDT under the lid or something like boss pedals)
Post by: micromegas on March 25, 2015, 03:03:19 PM
my local dealer has this one:
http://www.retroamplis.com/epages/62070367.sf/es_ES/?ObjectPath=/Shops/62070367/Products/ENC-MDC532
Post by: micromegas on March 25, 2015, 03:14:04 PM
in what part of france do you live? I have family in the champagne region (near Troyes)
Post by: Coda-effects on March 25, 2015, 03:18:32 PM
Actually I live in Paris !
Champagne region is nice area, you should visit them asap :)
The enclosure seems really nice, I have to make a small cardboard model to see what size it is, but maybe it will do the job !
Post by: peAk on March 25, 2015, 03:18:54 PM
you can see if David has any left here:
http://www.effectsenclosures.com/
Post by: davent on March 25, 2015, 04:21:26 PM
Mac's wedges are really nice but much bigger then a 1590b, ~1"/(25.4mm) longer and ~3/4" wider and taller at the tall end, just slightly smaller then a 1590J. He may be sold out again as well.
Mike (haveyouseenhim) chopped a 1590A but he had to come up with a switch to work in the shallow end, nothing off the shelf.
For a shallow switching scheme might try something like the Geofex pancake switch.
http://www.geofex.com/Article_Folders/footswitch_pancake/footswitch_pancake.htm
Chopped 1590J and a Mac wedge (white).
(http://i216.photobucket.com/albums/cc305/davent/IMG_6712_zpsb31347ca.jpg)
(http://i216.photobucket.com/albums/cc305/davent/IMG_6709_zps9f5a576c.jpg)
(http://i216.photobucket.com/albums/cc305/davent/IMG_6711_zps04546ead.jpg)
Post by: Coda-effects on March 25, 2015, 04:53:48 PM
QuoteFor a shallow switching scheme might try something like the Geofex pancake switch.
This is a good idea ! I have to go in the detail a bit.
I will receive microswitches soon (momentary...), so hopefully I can try to adapt it to a standard 1590B enclosure (or 125B)
However I am not very confident with the reliability of microswitches... But that could be a good idea
I already thought of a way to make the rubber pad, using engraved rubber people use for inkstamps
Post by: davent on March 25, 2015, 05:35:39 PM
I tried a piece of mouse pad and it takes a good bit of force to get the switch to actuate. As far as switch life, the Panasonics i bought are rated at 2M cycles minimum, as long as you've got it set up properly and it's not going to be physically crushed, should last forever.
http://industrial.panasonic.com/lecs/www-data/pdf/ATK0000/ATK0000CE28.pdf
Post by: Coda-effects on March 27, 2015, 10:25:35 AM
Do you have any pictures of your build with this kind of switching system?
I was wondering about the height of such a system...
Post by: davent on March 27, 2015, 11:32:38 PM
I only ever got around to prototyping so haven't a completed project, have a project sitting there ready to accept it, on the todo list. Total height, just measured and took some pictures but need my computer... total switch height is between 11 & 12mm, that's two layers of 3mm acrylic, 3mm mouse pad, 1.5mm aluminum plate and a ~0.35mm pcb. Geofex has the switch glued to the top of the enclosure, i was making it on the aluminum plate and attaching the plate to the enclosure with screws on the inside under the plate. Used a Geofex latch circuit in conjunction with mictesters relay switching circuit to do the bypassing.
http://www.freestompboxes.org/viewtopic.php?f=13&t=13295&sid=4740ac16be8b551422045e905861b2d6
Think it was the 4049 latch in this article http://www.geofex.com/article_folders/cd4053/cd4053.htm
... and if i recall correctly the LED and switched relay state were not always in sync at power up.
Post by: TGP39 on April 10, 2015, 02:32:25 AM
Hi Coda.....I found this on Ebay....
http://www.ebay.com/itm/320781926498?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
It looks like just what you are looking for..
steve.
Post by: davent on April 10, 2015, 04:08:35 AM
Quote from: Coda-effects on March 25, 2015, 01:45:34 PM
Hello !
But a lot smaller
DIY 1590B stepped wedge tutorial.
http://www.diystompboxes.com/smfforum/index.php?topic=110590.0
Post by: Coda-effects on April 10, 2015, 06:32:11 AM
Finally I decided to go for the switching system with a pad.
I just saw this picture of the original superfuzz:
(https://reverb-res.cloudinary.com/image/upload/a_exif,c_limit,fl_progressive,h_620,q_85,w_620/v1408242706/zsetwvgwwej5b8qeuc7j.jpg)
We can see that there is a typical 2PDT switch, but it is just a bit deeper in the enclosure.
So I thought of this system:
(http://tacticmagic.voila.net/system.png)
Do you think it can be thiner, and do you thing it can work ?
On the third picture of this ebay auction, we can clearly see that there is a metallic pad below the plasctic pad, with a bent aluminium portion: http://www.ebay.com/itm/VINTAGE-UNIVOX-SUPER-FUZZ-EFFECTS-PEDAL-SHIN-EI-MADE-IN-JAPAN-UNICORD-BLACK-/221556296557?pt=LH_DefaultDomain_0&hash=item3395c8cb6d
I will try both system anyway
The PCB is still under produciton, so I have a bit of time to think about that
Post by: davent on April 11, 2015, 03:49:20 AM
Using the Cozybuilder tutorial i linked to above, came up with this hacked 1590B. Have continuity between the two glued together pieces.
(http://i216.photobucket.com/albums/cc305/davent/IMG_7021_zpslezkxak2.jpg)
(http://i216.photobucket.com/albums/cc305/davent/IMG_7048_zps0mwju8kk.jpg)
(http://i216.photobucket.com/albums/cc305/davent/IMG_7043_zpsbmtj25gc.jpg)
(http://i216.photobucket.com/albums/cc305/davent/IMG_7049_zpslhh9fhuq.jpg)
Post by: jtaormina on April 11, 2015, 02:40:07 PM
LIC pedals has painted enclosures on eBay that are wedge like that. He specializes in MKI And II replica stuff.
http://stores.ebay.com/LIC-Pedals-and-Parts
Post by: davent on April 11, 2015, 04:27:51 PM
Those wedges he's selling look an awful lot like Mac Walkers wedges right down to the machining marks on the raw boxes. They're much bigger then a 1590B. Mac has another run of his up for sale again. They are in fact Mac's, he has those ebay photos in his for sale thread.
http://www.diystompboxes.com/smfforum/index.php?topic=97548.msg1015838#msg1015838
Post by: jtaormina on April 11, 2015, 06:10:36 PM
Haha some even said LIC pedals on them. No idea who gets them from who but they are available on eBay. I will warn you guys I've been dealing with that guy through eBay and he is slow as hell.
Post by: Coda-effects on April 12, 2015, 07:05:49 AM
Thank you all for your input!
I will let you know what I will do
Post by: davent on April 12, 2015, 05:14:41 PM
Mac has joined the party.
http://www.madbeanpedals.com/forum/index.php?topic=20786.0
