Projects => Tech Help - Projects Page => Topic started by: ratobasher on January 28, 2015, 02:55:36 AM
Title: Sparklehorn Build
Post by: ratobasher on January 28, 2015, 02:55:36 AM
I've recently built two Sparklehorn projects. I used all 9mm metal pots. Wired it to use only one stomp switch. When a power supply, cable from guitar to pedal and pedal to amp are all connected, and pedal is in bypass mode, it makes a loud ground buzz sound. When I switch it effect mode I hear the delay and distortion and the buzz is grinding.  Has anyone had issues building this project.
Title: Re: Sparklehorn Build
Post by: ratobasher on February 02, 2015, 06:42:04 PM
Quote from: ratobasher on January 28, 2015, 02:55:36 AM
Has anyone built the sparklehorn and had issues? Are there any possible bugs with this board? Is this the wrong place to ask? Is there another Sparklehorn thread?
Post by: rullywowr on February 02, 2015, 06:46:01 PM
Welcome to the forum.
The best place to get help is in the "Tech Help" thread.  I am confident a mod will move this thread there soon.
Some detailed pictures of your build would be helpful as well as voltages on the IC's/Transistors.  Did you "rock it before you boxed it?"  (made sure it works on a test rig before putting it in an enclosure?
-Ben
Post by: ratobasher on February 03, 2015, 03:15:00 AM
Quote from: rullywowr on February 02, 2015, 06:46:01 PM
-Ben
Thanks for the advise. I did rock it before I boxed it. Still trouble shooting all the other points.
Post by: madbean on February 03, 2015, 08:03:59 AM
Is everything grounded properly? Are your jacks metal frame or plastic insulated. If the latter, you will need to ground the sleeves of both.
Barring that, a pic of your build will help.
Post by: ratobasher on February 05, 2015, 11:42:15 AM
Quote from: madbean on February 03, 2015, 08:03:59 AM
Odd thing is when i run a jumper from the cathode of D7 to the ground lug of the output jack, which is metal, i get the effect to to work.
