(http://i752.photobucket.com/albums/xx167/illcom777/zendrive005.jpg)
(http://i752.photobucket.com/albums/xx167/illcom777/zendrive009.jpg)
Cool, I like the graphic.
Josh
Cool!
What's the material you're using for insulation on the enclosure?
Good job. How do you like the effect?
Tokyo!
My home of the last four years...
Quote from: slimtriggers on May 19, 2011, 01:30:49 PM
Cool!
I'd like to know this too.
Thanks everyone
The insulation is simple plastic sheet i glued there with superglue
Tokyo that's right Pandadan
I call it the tokyo drive. I'm suprised someone knew what it means
I guess the www is wider than i tought ;)
Quote from: bigmufffuzzwizz on May 19, 2011, 03:07:34 PM
I like it... I needed a really low gain overdrive, that I could play open chords without palm muting too much, it works fine but I didn't test it that much, band practice tomorow will tell me.
