Projects => Build Reports => Topic started by: raulduke on November 11, 2014, 06:14:21 PM
Title: CE2 Clone (BYOC Analogue Chorus)
Post by: raulduke on November 11, 2014, 06:14:21 PM
Not posted any builds for a while!
Here is my BYOC Analogue Chorus I built recently.
Lovely, lovely chorus; probably my favourite I have tried so far. Nice and 'warm' (for want of a better word).
It's been a while since I have built a BYOC kit and I forgot how much fun they are to put together.
I added a small mod; a switch to bypass the dry signal mix, giving an approximation of 'vibrato'.
The vibrato sounds pretty good considering the circuit and LFO are not optimised for it.
This is where the BYOC megachorus comes in (next on the list of 'must build' BYOC kits)...
(http://i1195.photobucket.com/albums/aa381/stevo83/17d27686-b014-4d3b-8f09-0cc54c5f7e73_zps3db6b21c.jpg)
(http://i1195.photobucket.com/albums/aa381/stevo83/057CF74E-9C26-43F3-BF1C-155FC3CE2593_zpserjfcnfu.jpg)
(http://i1195.photobucket.com/albums/aa381/stevo83/d863a343-e931-4b55-938f-499d8beb1d6f_zps83572a44.jpg)
Title: Re: CE2 Clone (BYOC Analogue Chorus)
Post by: Matt on November 11, 2014, 08:12:03 PM
Very nice. I like the "Ensemble" font. Don't know if I'm seeing this right, is the board angled to allow for the switch?
Post by: bcalla on November 11, 2014, 08:44:36 PM
You've got a cool art deco thing going on there.  Outstanding graphics.
Post by: cooder on November 11, 2014, 09:06:00 PM
Looks superb all around and your deacl style is super! Dig it! 8)
Post by: Hogharry on November 11, 2014, 10:43:08 PM
Looks very nice indeed! I have to agree that it's a lovely sounding chorus.
Post by: pedalhealer on November 13, 2014, 07:56:39 AM
Very cool! Is the graphic is sticker?
Post by: raulduke on November 13, 2014, 09:49:17 AM
Yes mate its a polyester clear label.
Work really well for graphics (better than decals I have used)!
A few coats of enamel clear coat and the labels semi-meld to the enclosure.
Post by: LaceSensor on November 13, 2014, 01:29:54 PM
Quote from: raulduke on November 13, 2014, 09:49:17 AM
link me to the supplier? Id like to try them. are they for lazer printers?
I used to use inkjet decals but they were not very robust.
Post by: raulduke on November 13, 2014, 02:20:59 PM
Quote from: LaceSensor on November 13, 2014, 01:29:54 PM
Here you go:
http://www.aalabels.com/home/buy/2474 (http://www.aalabels.com/home/buy/2474)
They are Matt (what I use at the moment), but they also have now have a gloss variant which might be worth try out (probably require less clear coat to get a nice flat finish)
They are a good company. Use them at work for all sorts of things (well... labels  ;D).
Post by: lars on November 13, 2014, 04:22:28 PM
I too have used this method.
I use the #18665 label sheets from Avery.
It works really well for complex, big graphics where a waterslide decal might stretch and distort straight lines. You could realistically print out up to an 8.5" x 11" graphic that would be nearly impossible to do with a decal in one piece. I like to put a light coat of clear on after it dries to protect the ink while I'm putting it on the enclosure, then several coats of gloss, and it looks like paint.
Great-looking build!
Post by: LaceSensor on November 13, 2014, 04:26:22 PM
Quote from: raulduke on November 13, 2014, 02:20:59 PM
Here you go:
quite pricey
avery do similar stuff for about £15 per 25 sheets
might investigate regardless
Post by: luks999 on November 13, 2014, 05:41:13 PM
Here you go:
your pedals look fantastic with these!
are these polyester labels self adhesive ? do you use clear laquer to seal it?
Post by: raulduke on November 13, 2014, 05:43:42 PM
Quote from: LaceSensor on November 13, 2014, 04:26:22 PM
Here you go:
quite pricey
Work well for me but suit yourself.
'your pedals look fantastic with these!
are these polyester labels self adhesive ? do you use clear laquer to seal it?'
Yes they are self adhesive and I use clear enamel lacquer.
You have to be very careful when applying the label; make sure you are straight because you will take paint of if you try and remove it after applying (I know this from experience  ;D)!
Post by: luks999 on November 13, 2014, 05:58:02 PM
Thanks, raul ;)
i think i give these label a try :)
Post by: mweint on October 12, 2016, 06:29:38 AM
Hey, sorry to revisit this post after so long.  Just curious as to what you mean that the LFO and circuit are not optimized for vibrato.  I always thought chorus and vibrato were the same except for the addition of the dry signal in the mix and the vibrato effect being delayed a bit.  Would love to understand more about what optimizes a circuit for vibrato if you have any info on that!  Thanks so much.
Post by: Boba7 on October 12, 2016, 07:26:09 AM
mweint > The CE2 uses a triangle wave, and for a smooth vibrato a sine wave is better (I prefer it too)
I had modded my CE2B to have a sin/triangle switch as well as a vibrato switch. Can't remember what I did exactly, but you can find lots of infos online.
Post by: nzCdog on October 13, 2016, 02:45:34 AM
Very cool build Steve... worth a forum dredge for sure 8)
Post by: warriorpoet on October 13, 2016, 03:58:10 AM
This thing is killer man. Wow.
Post by: raulduke on October 18, 2016, 11:42:14 AM
Cheers guys!
Can't believe this build is 2 years old... I really need to upload some more builds  ;D
Also, yep by improving for vibrato I mean the LFO shape.
I also like a bit of tone control on vibrato. I find that cutting treble makes it sound even nice (love my BYOC ultimate chorus/vibrato for this).
Post by: brucer on October 19, 2016, 12:37:13 AM
Damn.  That's a fine looking pedal.  I like mine.  Just modded it to include a blend and CE-2/2B switch.
Post by: nzCdog on October 19, 2016, 12:47:51 AM
Quote from: raulduke on October 18, 2016, 11:42:14 AM
Cheers guys!
Indeed you must 8)
Looking at your post count, almost time to party like it's 1999? ;D
Post by: raulduke on October 19, 2016, 02:52:46 PM
Quote from: nzCdog on October 19, 2016, 12:47:51 AM
Cheers guys!
Indeed you must 8)
Ha ha too right.
And I'll try to celebrate by posting a build report or two  ;)
Post by: mweint on October 19, 2016, 08:21:57 PM
Ah I see. Thanks for the info.  I also found that the vibrato signal is a lot quieter than the dry so after  just cutting the dry there's a pretty big volume drop when the effect is turned on.  Was that your experience too?
