I am replacing a pot in my jazz bass but could only find the value I needed (50k push/pull) in a smaller sized shaft pot. What can I do to use this pot, but stabilize it in the slightly larger hole?
I think McMastercarr may have a bushing for the job.
I used a piece of 1/4" brass rod and a drill press to make my own 1/8" shaft to 1/4" knob adapter.
(http://i216.photobucket.com/albums/cc305/davent/IMG_0907_zps6c434544.jpg)
Depends how much is "slightly", and if it's a push on or a set screw type knob.
If the difference in diameters is small (i.e. you could measure it with calipers but it's not visually apparent) and it's a set screw type knob, you could build up the shaft with heat shrink tubing fairly easily.
Otherwise, go with Dave's suggestion.
EDIT - if it's just the diameter of the hole in the pickguard/control plate you're worried about, a second larger flat washer will do the trick.
Quote from: GermanCdn on November 05, 2014, 11:32:20 PM
That's a wicked awesome idea for the heat shrink tubing......I bet I'll use that someday. Thanks.
Why f@#k about, go to ebay and buy the right one, fix it once and fix it right. :)
And pay money?
;D Either that, or i'm sure Curtis could send you one, from one of the 100? plus guitars he's not currently playing at this very moment ;)
