General => Open Discussion => Topic started by: adam_bz on November 04, 2014, 09:33:27 PM
Title: acoustic distortion pedal
Post by: adam_bz on November 04, 2014, 09:33:27 PM
Any suggestions on a distortion that sounds good on acoustic?
Title: Re: acoustic distortion pedal
Post by: Betty Wont on November 05, 2014, 03:31:59 PM
I find it helpful to use a gate and good EQ section to tame feedback. The Devi Ever Hyperion is the best gain pedal I've played by itself on acoustic. It has a great natural gate, very little high end feedback and if you voltage starve it you get much more low end and lower gain OD and crunch.
Post by: lars on November 05, 2014, 04:31:53 PM
Another thing to really consider is the quality of your acoustic pickup/preamp setup and if you're using an acoustic guitar amp. An acoustic guitar with a good electronic setup that has the correct impedance can be connected to a regular guitar amp. That in turn opens up a ton of choices of effects that can be applied. I've never tried running regular guitar effects into an acoustic guitar amp, but I can imagine it might not work as well since acoustic amps are usually voiced differently.
