i have builded a small booster a SHO with rullywow layout, but i see many people that build with larger pcbs, like a zero point micro, but in my experience. i cant fit switchcraft open frame jacks and leave enpug space up for the pcb, i tried that on my SHO and was a real fail, because when i plug the cable it gets grounded and its really hard the un-plug, now i want to fit a cavedeweller, but again open frame jacks are too big, i see mad beans uses some low profile jacks, but link on small bear its dead, any sugestions??
Check out the MB Baby Board Guide at http://www.madbeanpedals.com/downloads/BabyBoardGuide.pdf (http://www.madbeanpedals.com/downloads/BabyBoardGuide.pdf). I haven't tried one of the baby boards in a 1590A yet, but I'm considering it.
I see the document link to Small Bear's site for low-profile, stereo PC mount jacks is broken, but there are three options on their Neutrik page: http://www.smallbearelec.com/servlet/Categories?category=Plugs%2C+Jacks%2C+Fittings%3ANeutrik (http://www.smallbearelec.com/servlet/Categories?category=Plugs%2C+Jacks%2C+Fittings%3ANeutrik)
The document link to Mouser's site still works: http://ca.mouser.com/Search/ProductDetail.aspx?R=NRJ4HFvirtualkey56810000virtualkey550-10284 (http://ca.mouser.com/Search/ProductDetail.aspx?R=NRJ4HFvirtualkey56810000virtualkey550-10284)
Hope that helps.
I like standard sized enclosed jacks for 1590a builds. I use three different manufacturers:
- Switchcraft
- Neutrik
- Amphenol
I just recently got the Amphenol for the first time. The cool thing about those is that they have sharp flanges that dig into the enclosure as you tighten the nut. This is helpful since there isn't room for a lock washer on a 1590a build.
Quote from: pickdropper on September 26, 2014, 07:46:16 PM
- Switchcraft
- Neutrik
- Amphenol
can you post pictures or links??, i used switcraft but, only leave room for the jack, noboard can be up the jacks
I believe this is type Dave is refering to.
(http://www.pedalpartsplus.com/mm5/graphics/00000001/Switchcraft%20Enclosed%20jack.jpg)
Yep, that's the style.
Quote from: davent on September 26, 2014, 10:58:13 PM
those are boss typo, i just disamble a boss i had bad and man, they are perfect for the 1590A, even though i had drilled for open frame jacks, i can gain some high with this ones, small bear sell them??
Small Bear and the big guys if they work for you. Part #111 if you're searching out the Switchcraft.
http://www.smallbearelec.com/servlet/Detail?no=90
http://www.taydaelectronics.com/hardware/6-35mm-1-4-plugs-jacks/6-35mm-1-4-stereo-phone-jack.html (http://www.taydaelectronics.com/hardware/6-35mm-1-4-plugs-jacks/6-35mm-1-4-stereo-phone-jack.html)
Tayda has similar for .45 cents each.
don't know which are better or worse...
Quote from: blearyeyes on October 01, 2014, 10:34:09 PM
i got some cheap i bought at my country, and when i was locking the jack it breaks, so i think those cheapo are really bad, but the boss ones are the same but better quality
I use these in all my builds, and they are perfect for 1590A enclosures.
