Projects => Tech Help - Projects Page => Topic started by: Doc Plus on April 29, 2011, 07:17:03 PM
Title: Sunking IC3 voltage issue
Post by: Doc Plus on April 29, 2011, 07:17:03 PM
Hi,
IC1 = TL072              IC2 = TL072                 IC3 = MAX1044CPA
4.6                          4.6                             9.3
4.6                          4.6                               0 (should be 4.6)
1.2 (should be 3.4)     4.6                               0
0                              0 (should be -8.5V)        0 (should be -4.5V)
4.5                           4.6                              0 (should be -8.5V)
4.6                           4.6                             4.4
4.6                           4.6                             4.2 (a bit low)
9.3                           8.2  (should be -16)       9.3
Moreover IC3 is very very hot. All the electrolytic caps are 25 or 50V. I replaced them all but it changed nothing. I also replaced the zener.
I tried 3 different IC3 but all were MAX1044CPA. I read I should use MAX1044SCPA.
Do you know a place where to buy one with low shipping ?
What's the difference between CPA and SPCA ? Could this explain why my IC3 is so hot ? I can't let my finger on it !
Title: Re: Sunking IC3 voltage issue
Post by: madbean on April 29, 2011, 08:29:38 PM
Yes you should use the SCPA, but there is something else going on there with your build. If the IC gets hot, there are only a couple of causes: it's in backwards, or there is a bad solder or solder bridge somewhere. Given that you are reading 0v on pins2 and 5, I would look for a place where those are grounding out.
One last thing: it could be a faulty electrolytic cap...C18, C19 and/or C20.
Post by: Doc Plus on June 17, 2011, 02:04:40 AM
I received two 7660, so no excuse to try again ...
The problem was that pin 2 & 4 of IC3, C21 + & - and C20 - were grounded.
I desoldered IC3 support, C21 and C22, and the problem was still there ... which means the problem came from the PCB.
So I resoldered an IC support but I removed pin 2 and 4. I soldered C21 directly to MAX1044, and C20 - directly to C21 +.
Now my sunking is working.
