General => Open Discussion => Topic started by: culturejam on June 02, 2014, 01:19:12 AM
Title: Recommend me a small/cheap mixer
Post by: culturejam on June 02, 2014, 01:19:12 AM
Mixing boards are something I've mostly ignored or avoided my entire life.  ;D
As a consequence, I don't know much about them. What I do know comes primarily from using my old Tascam 424's in-built mixing functionality. It seems like a lot has changed over the past 10 years or so in the world of small and inexpensive mixers.
I will be getting a mixer in the very near term. I want to do better pedal demo recordings, and maybe some fun silly song projects. For mics, I have a SM57 and Sennheiser e609, so I feel like I've got that covered. I will be outputing to either Garageband on iPad or Reaper on a laptop. I also have an iRig Pro. I will not be using the mixer for any live performances.
So what would you guys recommend for a mixer? My budget is "as low as possible that will adequately get the job done", although I'd be willing to kick in a bit more for something that makes the overall process easier/faster/more convenient.
Title: Re: Recommend me a small/cheap mixer
Post by: culturejam on June 02, 2014, 01:38:26 AM
I guess maybe a good starting question would be: Do I even need a dedicated mixer?
Could I use a mic preamp with multiple inputs to accomplish the same thing?
Post by: oldhousescott on June 02, 2014, 02:02:50 AM
I know we all tend to poo-poo Behringer stuff, but really, it's ideal for just this thing. They have several sub $100 models (some around $50 or so) with one or two (or more) mic preamps and simple high/low eq. Some even have USB with built-in converters that probably don't suck for what you're wanting to do. You'll get a nice, strong headphone output that way, and it will double as an audio interface.
Post by: stecykmi on June 02, 2014, 02:16:20 AM
scott makes a pretty good arguement. if you like the idea of a mixer that doubles as an audio interface, there are other boards on the market. makie, soundcraft, allen & heath all make comparable products.
Post by: jtn191 on June 02, 2014, 02:55:31 AM
I agree with Scott too. An audio interface allows you to record multitracks at the same time. But if you're only looking to record two tracks, you could use any mixer--pan one track left, one right--and the stereo outs become track one and track two.
I'm selling my Tascam FW-1804 which is a Firewire interface (ports most commonly found on macs). It's a considerable step up from the M-Audio Fast Track Pro I had before. I'm trying to sell it for ~$150. I feel like it's a pretty good deal since the newest US-1200 is $200, same # of xlr inputs but fewer digital inputs.
http://www.madbeanpedals.com/forum/index.php?topic=15782.0
Post by: lincolnic on June 02, 2014, 03:39:17 AM
Yeah, you're looking for an audio interface, not a mixer. Even if you got a mixer, you'd still need an interface to get your audio into your laptop - if you're only working with two mics at most, then a mixer would just be an unnecessary middleman. Most interfaces have two inputs anyway. Since you're recording digitally, you'll be mixing in your DAW anyway.
jtn191's FW-1804 looks like a good deal. At $150, that's probably a lot better than what you'll get elsewhere for the same price.
Post by: miter53 on June 02, 2014, 04:05:05 AM
I have a Behringer Eurorack UB802 I've hardly ever used. $25 plus shipping. PM me...
(http://imagizer.imageshack.us/v2/1024x768q90/842/lb4iu.jpg)
Post by: Morgan on June 02, 2014, 04:34:17 AM
I have some sort of Behringer 2-channel mixer with a USB output that works great for pedal demos and track by track building of songs on a DAW. I choose to not worry about this stuff too much and just go with the cheapo Behringers.
Quote from: miter53 on June 02, 2014, 04:05:05 AMI have a Behringer Eurorack UB802 I've hardly ever used. $25 plus shipping.
I'll happily take that off your hands if CJ doesn't want it. I could really use it for acoustic gigs.
Post by: rullywowr on June 02, 2014, 08:49:22 AM
I just got a Tascam US-366 and optional RC3F foot switch and couldn't be more pleased. Lots of I/O and the foot switch makes it easy to record play and stop. I like the fact I can use external preamps with it no problem. The preamps in the unit sound really clean as well.   Great value for the dough.
Post by: peAk on June 02, 2014, 11:59:11 AM
I prefer Mackie boards because I like how the each mute button also functions as an alt bus. I use this for recording to the DAW all the time.
As soon as I want to record something plugged into the board, I mute that channel, in then mutes it through the main board, sends it to an alt bus which is directly connected to my PC audio interface. No feedback loops.
The small Mackie boards are top notch, with great preamps, and really affordable.
Post by: culturejam on June 02, 2014, 01:20:41 PM
Okay, so if I get a small board like the Behringer or Mackie (http://www.sweetwater.com/store/detail/402VLZ4/), what's the I/O setup?
Two mics into the mixer, and then use the headphone out into either iRig or the sound card?
Post by: rullywowr on June 02, 2014, 01:33:41 PM
That would work but I feel that you are much better off getting a small two or more channel interface...this allows you to tweak the balance, panning, eq, etc all day long post recording.
Post by: culturejam on June 02, 2014, 01:34:29 PM
This Alesis cheapie looks perfect:
http://www.sweetwater.com/store/detail/MultiMix4USB/
2 XLR inputs and it has USB output. Not much in the way of frills, but I think it would do what I want.
Post by: peAk on June 02, 2014, 01:56:34 PM
Quote from: culturejam on June 02, 2014, 01:34:29 PM
Looks pretty good. My only issue is the 16bit/44.1
Is this the highest it will record?
Post by: culturejam on June 02, 2014, 02:07:25 PM
I can only assume that if did have a higher mode, they would have listed that it instead. ;)
This looks to be another option:
http://www.amazon.com/Behringer-Xenyx-Q802USB-Audio-Mixer/dp/B008O517IC/ref=sr_1_3?s=musical-instruments&ie=UTF8&qid=1401716516&sr=1-3&keywords=behringer+mixer+usb
Good old Behringer.
Post by: peAk on June 02, 2014, 02:10:45 PM
How many channels do you need?
Post by: culturejam on June 02, 2014, 02:16:48 PM
Realistically I'll be using one or two channels almost all of the time.
My lack of understand is centered around getting the audio into the computer. I'm confused on what exactly I need. Do I really need a mixer or just an audio interface with two XLR inputs?
Maybe all I need  is this Presonus interface:
http://www.sweetwater.com/store/detail/AudioBoxUSB/
Post by: peAk on June 02, 2014, 02:20:05 PM
Quote from: culturejam on June 02, 2014, 02:16:48 PM
Exactly! That is a good one.
Here is another option. M-Audio makes great drivers
http://www.sweetwater.com/store/detail/MTrack/
With either of these, you will also get a midi connection. Midi rules  8)
Post by: miter53 on June 02, 2014, 02:23:58 PM
Focusrite Scarlett 2i2 has worked great for me. That's why I don't use the Behringer mixer.
http://www.amazon.com/Focusrite-2i2-USB-Recording-Interface/dp/B005OZE9SA/ref=sr_1_1?ie=UTF8&qid=1401718938&sr=8-1&keywords=focusrite+2i2 (http://www.amazon.com/Focusrite-2i2-USB-Recording-Interface/dp/B005OZE9SA/ref=sr_1_1?ie=UTF8&qid=1401718938&sr=8-1&keywords=focusrite+2i2)
Post by: culturejam on June 02, 2014, 02:30:12 PM
Thanks, guys. Looks like I'll be getting one of the dual-input interfaces. And I'll likely keep my iRig for quick recording through iPhone and iPad.
Post by: peAk on June 02, 2014, 03:13:09 PM
cool, good luck!
BTW, what Audio Recording Software are you going to use? Have you decided?
Post by: culturejam on June 02, 2014, 03:38:48 PM
Quote from: peAk on June 02, 2014, 03:13:09 PM
Reaper
Post by: peAk on June 02, 2014, 03:42:38 PM
Quote from: culturejam on June 02, 2014, 03:38:48 PM
Reaper
Ahh cool, people seem to really like it.
Good luck with whatever you decide on. Any of those should work fine.
Post by: jkokura on June 03, 2014, 04:40:44 PM
I'll put my two cents in and recommend the Presouns Audiobox 22VSL. It does what you're looking for, and also includes a free basic DAW called Studio One. I use a 44VSL and I upgraded to the Pro version of Studio One and I'm very, very happy.
Another benefit is that these can easily be used in live situations if that's something that you require.
Get a good sale and the 22vsl is relatively inexpensive.
