Projects => General Questions => Topic started by: fman7 on May 25, 2014, 02:46:02 AM
Title: Where to get 392k & 422k for Kingslayer / Sunking?
Post by: fman7 on May 25, 2014, 02:46:02 AM
Hey,
having trouble sourcing the 392k and 422k resistors for the Kinslayer/Sunking builds.
Can I use 390k and 430k?
thnks
Frank
Title: Re: Where to get 392k & 422k for Kingslayer / Sunking?
Post by: jubal81 on May 25, 2014, 03:18:55 AM
Generally, within 5% is considered irrelevant because that's the tolerance of a typical carbon film resistor. Along those guidelines, those values should be fine.
Post by: selfdestroyer on May 25, 2014, 04:37:49 AM
Got mine from Mouser
http://www.mouser.com/Search/ProductDetail.aspx?R=271-392K-RCvirtualkey21980000virtualkey271-392K-RC (http://www.mouser.com/Search/ProductDetail.aspx?R=271-392K-RCvirtualkey21980000virtualkey271-392K-RC)
Post by: Stig on May 28, 2014, 09:24:41 PM
I put two in series to get the correct value. Plus it looks funny:-)
Post by: rullywowr on May 29, 2014, 12:13:23 AM
Mouser FTW with these funky values.
Post by: fman7 on May 29, 2014, 09:22:18 PM
Thanks for responses, will go for the series option.
Should have mentioned I'm in Australia, so Mouser etc is out of the question.
thnx
Frank
Post by: davent on May 30, 2014, 03:06:17 AM
There's also the parallel option, plug in the desired resistance and the % tolerance - the software spits out every possible pair that meet your parameters.
http://www.sengpielaudio.com/calculator-parallel.htm
Post by: Stomptown on May 30, 2014, 04:56:31 AM
If your hung up on the values you can always buy a bunch of 390K and 422K and measure the resistance to find a 392K and a 422K. In this case I would go with carbon film 5% tolerance resistors to make it easier. I tried to do it with 1% metal film and it took a while to find a match. Lie mentioned above, it's not really a big deal...
