Projects => Build Reports => Topic started by: pandadandan on March 26, 2010, 04:28:24 PM
Title: Mysterioso Jr.
Post by: pandadandan on March 26, 2010, 04:28:24 PM
(http://i172.photobucket.com/albums/w20/pandadandan/mysterioso.jpg)
Hot off the soldering iron!
Going to play with the cap values in the top switch; I think some parallel 500pf and 700pf ceramics would be good instead of the film caps.
Title: Re: Mysterioso Jr.
Post by: madbean on March 26, 2010, 04:38:47 PM
Awesome wiring! But, no pictures of the top side?? Anything interesting going on there?
Post by: pandadandan on March 26, 2010, 04:47:31 PM
Quote from: madbean on March 26, 2010, 04:38:47 PM
(http://i172.photobucket.com/albums/w20/pandadandan/mysterioso-top.jpg)
Haven't finished really; still have to stamp out the controls on the copper plate.
For this one, instead of tarnishing the plate with salt water as I did with the Poindexter, I heated it until it was glowing hot, then threw it in our kitchen sink.  Made a lovely hissing sound  ;D
The wife wasn't impressed...
Post by: lincolnic on March 26, 2010, 04:54:44 PM
After looking at this and your other builds, I have to say that these are some amazing builds. What's the process of stamping those copper plates like?
Also, can I ask how you got your wires to hold such crisp right angles? It's a work of art in there!
Post by: pandadandan on March 26, 2010, 05:04:38 PM
Quote from: lincolnic on March 26, 2010, 04:54:44 PM
Copper plates are stamped with a hammer and a cheapo set of 4mm alphabet stamps.
The wires are smallbear's amazing ***amazing*** pre-bond 24awg hookup wire.
I live in Japan, yet I still order the smallbear prebond stuff because it's so good.  A pair of pliers and a flick of the wrist are all you need for nice 90 degree bends.
Post by: lincolnic on March 26, 2010, 05:09:36 PM
Quote from: pandadandan on March 26, 2010, 05:04:38 PM
Hey, that's exactly the wire I bought for the builds I'm working on now. I'll have to try it for myself.
Post by: pandadandan on March 27, 2010, 05:28:36 AM
Quote from: lincolnic on March 26, 2010, 05:09:36 PM
Go for it!  Just don't try to flex it too many times or the bonding breaks down and it reverts to standard multicore behaviour.
I also recommend the switch wiring system I use; it negates the need for the optional pulldown resistors in a lot of builds as everything is grounded all the time.
1 2 3   -  -  -
4 5 6   -  -  -
7 8 9   -  -  -
Consider the numbers as the pin locations.
The ground wire goes from the ring of the input jack to pin 7, through pin 7 to pin 2 (bare wire) then to the ring of the output jack.  PCB ground goes to the input jack, too.
Input wire goes to pin 8 through to pin 3.
Pin 5 goes to effect input.
Pin 9 goes to effect output.
Pin 6 goes to output jack tip.
Pin 4 goes to your LED -ve.
This wiring layout lets you get some nice straight lines if you want to be as OCD as I am.  Hahah.
Post by: gtr2 on July 10, 2010, 12:42:10 PM
How does it sound...?  Interested in possibly building this.
Post by: maysink on July 10, 2010, 09:46:33 PM
Quick question on the alternate switch wiring: How are you grounding the power adapter? I don't see anything completing the circuit--I see power going to the PCB & the LED but the ground lug on the adapter looks vacant...
I'm going to try this scheme for the hell of it!
Post by: pandadandan on July 12, 2010, 04:38:54 PM
Quote from: maysink on July 10, 2010, 09:46:33 PM
It's the flash making it hard to see.  Look between the power ground lug and the input jack.  The ground lug is hardwired to the jack by a short (5mm) bare wire.   ;D
Post by: maysink on July 16, 2010, 05:02:23 PM
That's what I figured but even after you mention it I can barely see it! Tried this method on a gruntbox I finished earlier this week and it works as expected. I may try it on my byoc optical compressor which pops EVERY TIME regardless of cables, amp and power supply.
