Yo,
So i put one decal on the first enclosure i made for about 2 years, so i miht have forgotten something ...
It's a clear inkjet decal from musikding, i used them before without problem.
This decal has lot of large areas with air under itn even if it sticks correctly.
I wonder what i could do to prevent that. Is is possible that i did not let it long enough in water?
I was trying to move it from the support in water to minimize water exposure time.
any advice is welcome.
Thanks in advance
For accepting the decal, did the top of the enclosure have a good puddle of water on it?
Im not sure if its the time in water! If released the backing paper easily shouldn't be the issue! Assuming the enclosure surface was very clean iy might help to spread some water on the surface before sticking the decal! You could also just shift a little of the backing, attach the top part, and release the rest by pulling the backing slowly. With the water pads underneath u can squeegee the bubbles.
Chromesphere has a nice video on utube showing this!
Good luck
For the experienced watersliders... Can one just do the whole thing under water? Submerge everything and take it out when it's done?
sent from my mobile device
I put a drop of dishwashing soap in. Makes it easier to slide around. Then place the backing paper on top of the decal, slimy side down and I use a credit card to squeegee the air bubbles out. I learned that from watching a guy at BestBuy put the screen protector on my phone. I've only done a few but so far so good.
DISHWATER SOAP!!
That's it, i used to mix dishwater soap with water into a spray and i would spray the opt of the enclosure with it, the soap keeps the water on top. i guess i had not enough water on top of the enclosure, i remembered it was less than before, but i couldn't remember why ..
Thanks for helping. dishwater soap i will use for the next enclosure!
thanks
thanks
thanks
thanks
Yeeeeess!
just a little drop of detergent is enough!
you dont want some foam around ehheeheheh
ok guys,
back on the forum after a new decal has been applied on a pedal, using water with a bit of soap into it in order to wet the whole surface of the pedal before applying the decal.
I have less air bubbles, but they are still here .. i'm so confused, i used to do that without any problems.
Here is the detailed process :
-print the decal (musikding inkjet decal)
-varnish it (i put slightly more varnish than i usually do this time)
-once it's dry -> cut the decal to pedal size
-prepare some water with soap
-put the decal in the same (with soap) water and wait 2 mins to detach it from the base, then 30 more seconds to be certain it's really wet and the adhesive is activated on the whole decal surface
-put the pedal surface into the water and when i remove it, assess that i still have water on the whole pedal surface
- gently put the decal over the surface and adjusting it a bit
- take a credit card and gently slide it over the decal holding it in place, to remove most of the water trapped between the decal and pedal
- go to sleep because it's 2am
- take the pedal back the following morning and see it's still not good enough.. :(
here are some pics so you can see what the bubbles look like
any ideas and help would be appreciated
Looks to me like you're waiting too long in the water. Also need to make sure your water is lukewarm.
Check out Chromesphere's video for more help:
Is that a high gloss blue? I've had the same issues with high gloss paints, I've found satin works better, and lately I've been soling the enclosure in the same temp water as the decal, seems to help.
Quote from: Jabulani Jonny on March 08, 2014, 01:14:55 PM
I think so too! i leave mine under water for about 1 min max. Actully the water goes pretty fast to the the interface between label and backing.
other think that might be is that your surface has some dust. What you could do is to wetsand your surface witha 2000grit sandpaper just a bit to make all the surface even.
or you could also, clear coat, like 2 coats, let it dry and apply the decal over the smooth clear coat.
cheers
If you have any bumps on your paint, it can give you problems, the decal can't form around them tightly enough and it will leave a gap/bubble.
Just soak until the decal releases from the paper backing, no set time for release to take place so you have to keep testing the soaking decal to see if they'll separate. I use a damp piece of paper towel to smooth out the positioned decal squeezing out the water and air.
Great tip from Juansolo is to use the decal backing to smooth out the air bubbles. The little bit of adhesive left on the backing helps as well.
If the surface you're putting the decal on is reasonably smooth then you just need to force the bubbles out. You can use a pin to create an outlet but the easiest way is to use one of those credit cards you get in the mail but don't accept and use the front edge (tends to be more rounded) to gently swipe the excess water away like a squeegee. You are trying to drag the water (and air bubbles) to an edge where it/they can be removed. Don't use so much pressure that you move the decal or distort it, but be firm enough to work the decal flat and dry. Blot the squeeze out up with a bit of paper towel and keep working it.
Ok guys,
First, a big thanks for you all for helping me out with this! it's great to get help like this when you have questions. thanks!
So after watching Chromeshpere's video i realized that i was not draining enough water from under the decal after sliding it over the enclosure.
I was certain that the water trapped there would just evaporate and 'contract' the decal over the enclosure in a way.
So i redid 2 decals tonight, and used a credit card to remove ALL water from under the decal.. so far it looks really clean and i hope it will stay like that over the night.
i'll keep you in touch.
Thanks again for helping!
