Projects => Build Reports => Topic started by: Stomptown on December 12, 2013, 04:59:39 AM
Title: AquaBoy 2010 (MN3005 version)
Post by: Stomptown on December 12, 2013, 04:59:39 AM
I finally got an AquaBoy put together and I love it! The delay time is a bit limiting but for most of my live gigs it will be perfect. Hope you like... 😄
(http://img.tapatalk.com/d/13/12/12/gahyme2e.jpg)(http://img.tapatalk.com/d/13/12/12/ze7yva8a.jpg)(http://img.tapatalk.com/d/13/12/12/2a9atera.jpg)
Title: Re: AquaBoy 2010 (MN3005 version)
Post by: Stomptown on December 12, 2013, 05:49:02 AM
Decided to resend the faceplate and try some new knobs. Which are better???(http://img.tapatalk.com/d/13/12/12/yjamameh.jpg)(http://img.tapatalk.com/d/13/12/12/uguby3e5.jpg)
Post by: brejna on December 12, 2013, 08:10:31 AM
Great build, love it and I like second combination more.. :-)
Post by: juansolo on December 12, 2013, 08:38:31 AM
Very nice  8)
Post by: Cortexturizer on December 12, 2013, 10:56:55 AM
fantastic stuff!
I actually like the first combination more
Post by: DutchMF on December 12, 2013, 11:57:00 AM
Quote from: Cortexturizer on December 12, 2013, 10:56:55 AM
fantastic stuff!
+1 on both counts!
Paul
Post by: fendman on December 12, 2013, 01:31:41 PM
Jon, I like everything about this :)  The finish and the mood lighting really compliment it.
Very nice
Mike
Post by: mjcyates on December 12, 2013, 02:03:08 PM
Great build. I prefer option 1.
Post by: pickdropper on December 12, 2013, 02:16:56 PM
Great build.  The etch is perfect.
This would look really good with a transparent blue finish.  The finishing on the enclosure would probably look like waves.
Post by: spaceboss on December 12, 2013, 05:34:44 PM
Beautiful.  8)
I think the silver face of the first knobs are a better match for the enclosure, so I'll vote first too.
Post by: lincolnic on December 12, 2013, 05:58:20 PM
You guys are crazy, the second set of knobs is the jam.
Post by: billstein on December 12, 2013, 08:32:39 PM
Beautiful!
Post by: Govmnt_Lacky on December 12, 2013, 08:58:36 PM
Jon,
What pump are you using in there? Looks like a TC. Would think the LT1054 would be the only pump able to handle that kind of mA current.
Sweet build as always!!!
Post by: Scruffie on December 12, 2013, 10:21:01 PM
Quote from: Govmnt_Lacky on December 12, 2013, 08:58:36 PM
Jon,
The DM-2 isn't as bad as a memory man, not sure exactly what its current draw is but a 20mA chip might cut it close.
Be interesting to find out.
Post by: selfdestroyer on December 12, 2013, 10:59:51 PM
Very clean build. I love the new knob selection.
Post by: Stomptown on December 13, 2013, 01:56:44 AM
Quote from: Scruffie on December 12, 2013, 10:21:01 PM
Jon,
Thanks for the heads up. I didn't realize it might be an issue. I haven't had any problems but I will probably take it out until I can get an LT just to be safe.  :P
Post by: Scruffie on December 13, 2013, 02:00:26 AM
You'd mainly experience issues at shorter delay times (current draw increases as frequency does) if you're not, probably fine.
Post by: Stomptown on December 13, 2013, 02:21:13 AM
Quote from: Scruffie on December 13, 2013, 02:00:26 AM
what would the symptoms be?
Post by: Scruffie on December 13, 2013, 02:41:12 AM
Quote from: Stomptown on December 13, 2013, 02:21:13 AM
Most likely... it'd stop delaying or the delay would sound messed up and the 15v regulator output would get pulled down.
You could measure its current draw if you're worried... but I wouldn't worry about it.
Post by: Stomptown on December 13, 2013, 03:56:41 AM
Quote from: Scruffie on December 13, 2013, 02:41:12 AM
So I boxed it up and never got to play it at a loud volume with the road rage before tonight. There is an odd sound at the end of the repeats that was not there before I boxed it (running 9V at that point). I pulled the road rage and the sound is gone. I guess I will have to get an LT and try that out. Otherwise, I will just run it at 9V. I also have a BBD doubler on the way from Oshpark (thanks for the share Aballen) so I needed to relocate the road rage anyhow...
Post by: Scruffie on December 13, 2013, 04:05:33 AM
How did it sound, that could just be heterodyning clocks...
However as the LT is at a higher frequency if I recall it'll probably help anyway.
Post by: Stomptown on December 13, 2013, 04:47:33 AM
Quote from: Scruffie on December 13, 2013, 04:05:33 AM
It's as if a note is separating in two as the repeat decays. Very robotic sounding. You know the sound that transformers make when they transform? Kind of like that! That's the best I can really explain it and I already took it out so I can't get any audio.
Post by: richard_mcg on December 14, 2013, 07:58:48 AM
The knob selection and finish is a work of art!! ;D
