General => Open Discussion => Topic started by: selfdestroyer on September 12, 2013, 01:54:50 PM
Title: FET reverb idea
Post by: selfdestroyer on September 12, 2013, 01:54:50 PM
Not sure if this has been posted already but I came across a st at Offsetguitars that a dude made a FET version of the Fender 6G15. Here is the info and build doc.
http://surfybear.weebly.com/fet-reverb.html (http://surfybear.weebly.com/fet-reverb.html)
Title: Re: FET reverb idea
Post by: raulduke on September 12, 2013, 03:14:37 PM
Thats really cool.
Especially as I have a spare spring reverb tank knocking around  :)
I might put a PCB layout together for it.
Post by: selfdestroyer on September 12, 2013, 03:17:10 PM
thats what I was thinking also... might be a fun project without messing with tubes and high voltage. I don't think I'm ready for that yet. lol
Post by: jkokura on September 12, 2013, 03:28:28 PM
I wonder if I could apply a belton reverb to that as well...
Post by: raulduke on September 12, 2013, 03:32:39 PM
As good as the belton sounds... nothing beats real spring reverb IMO.
Plus Accutronics spring tanks are quite readily available (and quite cheap).
Post by: jkokura on September 12, 2013, 03:46:04 PM
Quote from: raulduke on September 12, 2013, 03:32:39 PM
Ah yes, but can you get one in a 125B?
Post by: raulduke on September 12, 2013, 03:48:18 PM
Quote from: jkokura on September 12, 2013, 03:46:04 PM
Nope... but that all adds to the fun  ;)
Post by: croquet hoop on September 12, 2013, 07:31:49 PM
Quote from: raulduke on September 12, 2013, 03:32:39 PMPlus Accutronics spring tanks are quite readily available (and quite cheap).
I'm sure midwayfair or pickdropper could get one in a 1590A  ;D
Post by: pickdropper on September 12, 2013, 07:55:05 PM
Quote from: croquet hoop on September 12, 2013, 07:31:49 PM
Do you mind if the tank hangs out of the side?
Post by: jkokura on September 12, 2013, 08:54:03 PM
yes.
Post by: pickdropper on September 12, 2013, 09:11:57 PM
In that case, the 1590a enclosure is going to have to be much taller.
Post by: jkokura on September 12, 2013, 09:20:45 PM
No.
Post by: pickdropper on September 12, 2013, 09:23:23 PM
Well, apparently accutronics will have to invent their new mini folded spring reverb tank then.
Post by: jkokura on September 12, 2013, 11:02:00 PM
You could also use a tesseract to create a break in the space time continuum and then create a larger space inside the 1590a. That way, you can have as long a spring as you want...
Wait. That's getting a little ridiculous. You only need a medium spring.
Post by: timbo_93631 on September 12, 2013, 11:12:28 PM
Quote from: pickdropper on September 12, 2013, 09:23:23 PM
I think it'll be SMD
Post by: pickdropper on September 12, 2013, 11:49:55 PM
Quote from: timbo_93631 on September 12, 2013, 11:12:28 PM
SMD = Spring Mounted Diagonally?
Post by: eldanko on September 13, 2013, 06:20:45 PM
1590A?
(http://thegloss.com/files/2010/03/zoolander.jpg)
WHAT IS THIS, A SPRING REVERB FOR ANTS?!?
Post by: pickdropper on September 13, 2013, 06:29:53 PM
It uses watch springs.
Post by: jkokura on September 13, 2013, 09:48:51 PM
Quote from: pickdropper on September 13, 2013, 06:29:53 PM
Dude. Now you're thinking.
The guy who gets plate reverb into a 1590A I will kiss. On the lips. Literally.
Post by: stecykmi on September 13, 2013, 11:19:19 PM
hmm cool, i think i might have finally found a use for my sk170s from the group buy
