General => Open Discussion => Topic started by: StratJunior on February 10, 2011, 04:13:40 AM
Title: What to Start with??
Post by: StratJunior on February 10, 2011, 04:13:40 AM
Hi,
An DIY effects noob here, and I really want to start building some of my own pedals,
how would you guys recommend I start?  ???
A Kit? (GGG, BYOC) ?
or
Is any Noob-rated project fine.
edit: I have soldering experience and have been practicing reading schematics......
Title: Re: What to Start with??
Post by: maysink on February 10, 2011, 04:26:08 AM
Hello! A kit from the places you mention will get you everything: drilled enclosure, PCB, instructions and necessary parts. All you have to do is assemble it and decorate/label the enclosure to taste.
Madbean just sells the circuit boards leaving you to source all the parts, find + drill an enclosure and assemble it all.
Good soldering skills are a must regardless which avenue you take and reading schematics will help if everything does not go right.
Lastly, BYOC & Madbean both have superb forums. I don't believe GGG has any kind of support forum...
Post by: StratJunior on February 10, 2011, 04:52:51 AM
Hey, thanks for the reply,
Now looking back my how I phrased my question was kinda stupid... :P
I get the difference between MadBean and the Kit Sites, I was just wondering wether it would be easier for a beginner to have all the pieces there, how hard is it to find all the parts on Small Bear/Mouser etc...??
And is any "noob" project fine, obviously some have more components to deal with and hunt down.....
Post by: Haberdasher on February 10, 2011, 05:02:05 AM
I built my first pedal right here.  If I can do it, you probably can too- but a kit would be a lot easier and you wouldn't have to worry about drilling the enclosure (although you can order them pre-drilled).
There are some pretty simple fuzz circuits as well as overdrive circuits too.  If you're looking for a compressor the cupcake is nice.  What kind of effect would you like to build?
Definitely don't try ordering from mouser on your first pedal.  Much easier from smallbear since almost everything they have is geared toward pedal making.
Post by: jkokura on February 10, 2011, 05:04:42 AM
I usually recommend people start with a kit if they have no experience whatsoever. However, if you feel brave it is possible start with a basic build from madbean. If you do, I recommend you get everything from one source (smallbear) and remember that you should spend a lot of time learning and reading. Going slow and not rushing is vital to having a successful build.
I really recommend looking at your pedal needs right now. Don't just build a pedal if it's easy or a kit. Build something you will want to use tomorrow and next year.
Post by: StratJunior on February 10, 2011, 05:22:32 AM
Quote from: Haberdasher on February 10, 2011, 05:02:05 AM
I was looking at the enclosures at Mammoth Electronics, cause I'd don't really think drilling is for me, and the pre-painted ones look real nice... ;D
Quote from: Haberdasher on February 10, 2011, 05:02:05 AMWhat kind of effect would you like to build?
Quote from: jkokura on February 10, 2011, 05:04:42 AM
Thats what has put me off buying a kit, nothing on those sites really excites me, But I do feel I need a new overdrive, I'm finding my FD-2 a little boring, I like my clean tone, but I want a little dirt, it changes my tone in a way I don't enjoy, Out of the projects here, the Serendipity, and the Slambox look cool, but I would love to build a Yellow Shark.
thanks for the fast replies  ;D
Post by: maysink on February 10, 2011, 06:12:09 AM
The Slambox & Zombii are pretty simple & satisfying MB builds. You can get all the parts (except pre-drilled enclosures) from small bear--mouser is a great resource but it's VERY easy to order the wrong part from them when you're starting out.
For the record: I'm very happy with my GGG tubescreamer kit build and love my BYOC Might Mouse (proco rat) and analog flanger kit builds.
Good luck and let us know how it goes.
Post by: StratJunior on February 10, 2011, 06:39:34 AM
How do you know when you're ready to make the jump from "Noob" to "Cowboy"??
Post by: jkokura on February 10, 2011, 06:44:59 AM
There's not much difference between them. Usually it's a higher number of parts, or more complicated wiring, or dealing with specialty parts. You could build a cowboy or even an expert project as your first build, but the chances of immediate success go down. What project are you interested in?
Post by: StratJunior on February 10, 2011, 07:20:24 AM
The Honey Bee "Yellow Shark" Clone,
From the clips I've heard of the pedal, it's nice and transparent exactly what I'm looking for, although I wouldn't mind trying out a slambox....
Post by: madbean on February 10, 2011, 10:21:38 AM
StratJunior - if you want to try the Slambox, I'll throw in the components for you. That way you only have to get the hardware like the enclosure, jacks, switch, knob, etc. etc. It's no bother....I have more resistors and caps than I'll ever need.
I'd offer with the YS but I'm out of that IC, I think.
Post by: StratJunior on February 10, 2011, 11:13:17 AM
Now that's customer service  ;D
That's honestly too much, Id love to buy the components with the pcb?
Post by: gtr2 on February 10, 2011, 11:45:30 AM
Where else can you get help like this!  Umm...only at madbean pedals!
Id recommend if your brave enough to just start here.  There are a lot of smart people (not me) around here with excellent build techniques and troubleshooting abilities.  My first build was a byoc kit.  It gets your feet wet, but it's much more satisfying with the builds here!  Drilling isn't really that hard if you center punch your holes, drill pilot holes, and then a step bit.  But you should do whatever your comfortable with.
josh
Post by: madbean on February 10, 2011, 11:58:42 AM
Quote from: StratJunior on February 10, 2011, 11:13:17 AM
Nah, I wouldn't offer if I didn't mind. Don't everybody else start pretending to be a new guy though....I gots to have my trannys! Err..maybe I should phrase that differently.
Post by: StratJunior on February 10, 2011, 12:22:51 PM
Thanks so much, i feel bad, and excited at the same time, like the kid who got the $100 present with $5 Christmas present cap.
So on the 15th? The day after my birthday :P
Post by: jkokura on February 10, 2011, 04:43:13 PM
Uh Brian. I've only tinkered around on a few things, but i was thinking about trying the slam of and I'm not sure about where to get parts from...
Hee hee... Oh and strat junior, the parts for the slam box are so few, it's likely only costing Brian a quarter. If you were to order the parts from smallbear it would cost no more than a couple bucks. The parts get a lot cheaper when you buy them in bulk like Brian, myself and some others do. The hardest part is getting enough enclosures, jacks, ics and switches!
Hope the first build goes well, and let us know if you need some help or advice. I'm easily reached by pm and email also. We expect you to post pictures of the fInoshed pedal too!
Post by: B_of_H on February 10, 2011, 05:37:54 PM
I started on kits.  I occasionally think back to when I first started and all the issues I used to have that frustrated me...that seem so simple and foolish now that I kinda know enough to debug things somewhat.
It takes a while to learn how to source the parts so the kits allow you to focus on the actual building process without worrying if you got the right stuff.
a simple boost is probably the best start.  I started on a BYOC OD pedal and it worked fine but then had some issues with other kits further down the road as things got more complex.
Post by: Jamiroking on July 18, 2011, 11:41:57 PM
It looks like I'm a bit late to the party with this thread but I had to put my thoughts on record as well.
I built a Krankasaurus and a Zombi and a compressor from Tone pad for my first builds. I had never soldered anything more than a broken guitar cable before that and they all turned out great. I even ended up making a mod for the compressor to be able to switch between a Dynacomp and a Ross version. The only way it was possible was through this forum. As you can see, Bryan leads the way in showing how welcoming everyone is here. You really can't go wrong with this kind of support.
Because of this, I really wouldn't be intimidated by the Cowboy or even Genius classifications and basically just think of it as how much time you want to invest. As the main difference I noticed was how many components are jammed on the board. Something I'd suggest that I did is get a couple and populate the boards at the same time - e.g. resistors on the zombii, then on the krankasaurus, then caps on the zombii, then krank...etc. This way you get your first taste of that step on the board with the most breathing room and have gotten the practice with the iron by the time you do the same thing on the more complex board.
I think the most important thing you need is just the willingness to learn and the desire to have a certain pedal. If you don't enjoy the process, you might get frustrated and decide its not worth the effort, especially as a beginner. But If you have both of those things, there's a bunch of really knowledgable people here waiting to help you with any problem at all.
