General => Open Discussion => Topic started by: croquet hoop on June 20, 2013, 11:07:59 AM
Title: Not so big 1 uF box caps?
Post by: croquet hoop on June 20, 2013, 11:07:59 AM
I received my first Tayda order yesterday (yay!) and everything looks good so far, except that their 1 uF box caps are waaaaay too big:
(http://monimag.eu/upload/1216/p6204780.jpg)
No complaint, the specs were written on the website, that's why I only ordered a few. But since I need them for several mini builds, I'd rather use some that are the size of the yellow one (which I got in a Tiny Giant kit, so I didn't source it myself). I know, X7R MLCCs and tants are the way to go when space is tight, but many baby layouts have space for box caps, so why not?
So, do you have any recommendation? I have a cart at mouser so I looked at a few datasheets for 63v 1 uF caps (Kemet R82 and MMKs, Epcos) but I'm not sure I can find anything the same size as the mysterious yellow cap.
Title: Re: Not so big 1 uF box caps?
Post by: alanp on June 20, 2013, 11:11:04 AM
They aren't box caps, but Tayda's monolithic caps are pretty dang small for 1uF.
Post by: Vallhagen on June 20, 2013, 12:06:49 PM
I havent searched every place or every product, but the Panasonic SMF series are pretty small (means: the smallest 1uF cap I have used so far).
Cheers
Post by: culturejam on June 20, 2013, 12:52:53 PM
You got the 100v 1u caps. Try the 63v instead:
http://www.taydaelectronics.com/capacitors/polyester-film-box-type-capacitors/1uf-63v-5-polyester-film-box-type-capacitor.html
They cost a little more, but they are a fair bit smaller.
Post by: midwayfair on June 20, 2013, 12:54:46 PM
Quote from: croquet hoop on June 20, 2013, 11:07:59 AMSo, do you have any recommendation? I have a cart at mouser so I looked at a few datasheets for 63v 1 uF caps (Kemet R82 and MMKs, Epcos) but I'm not sure I can find anything the same size as the mysterious yellow cap.
Here ya go. 8mm high, 7mm long, 3.5mm wide, 5mm lead spacing, MIGHT be short enough to fit in a 1590A. Nothing else is shorter than 10mm, at least not without having, say, the width be that size.
http://www.mouser.com/ProductDetail/Kemet/MMK5105J50J02L165TR16/?qs=sGAEpiMZZMv1cc3ydrPrF17gIuUB4mH1CfNYlSFYLOc%3d
Of course, there's a pretty good reason not to use them: minimum order of 2,000, and they're 91c each.
Post by: croquet hoop on June 20, 2013, 01:05:13 PM
Thanks for all the answers. Yes, I've seen the Panasonic caps, they are indeed shorter, but also wider, so that does not fit the bill. The 63v caps at Tayda have been out of stock for as long as I can remember (have they been restocked since February?), so I did not think of them as an option.
And thanks Jon, these would be the perfect size, but of course as you point out they're not really available  ;D
I googled the code printed on the yellow cap but found nothing about it. I guess I'll stick to tants and MLCCs. Thanks for looking into it anyway!
Post by: Govmnt_Lacky on June 20, 2013, 01:10:37 PM
HAve you considered multilayer CERAMIC? Or is that a bad word?  ::)
Post by: croquet hoop on June 20, 2013, 01:15:25 PM
Yes, I have. No, it's not ;D
I was just curious to see whether the size of the yellow box cap was common or not. Unfortunately, looks like it's not. But there are alternatives, so...
Post by: RobA on June 20, 2013, 01:17:32 PM
The 50V WIMA MKS 2 are 3.5 x 7.2 x 8.5 mm. Mouser has them and they aren't too bad price wise.
http://www.mouser.com/ProductDetail/WIMA/MKS2-1-50-10/?qs=sGAEpiMZZMv1cc3ydrPrF2CPLAojp4yW5Q0WRWoDlA8%3d (http://www.mouser.com/ProductDetail/WIMA/MKS2-1-50-10/?qs=sGAEpiMZZMv1cc3ydrPrF2CPLAojp4yW5Q0WRWoDlA8%3d)
Post by: midwayfair on June 20, 2013, 01:24:05 PM
Quote from: Govmnt_Lacky on June 20, 2013, 01:10:37 PM
MLCC = ceramic = monolithic.
And no, it's not a bad word. I use them all the time.
EDIT:
Quote from: RobA on June 20, 2013, 01:17:32 PM
OOHH! That's it. I guess I missed one (other WIMAs were not so small). :D
8.5mm is still a little tall for the average 1590A build, I think, but it could be possible.
Post by: croquet hoop on June 20, 2013, 01:25:33 PM
Oh, right, that could be interesting. Could the 10% tolerance be a problem? (I guess not since it's acceptable for MLCCs and tants, but I'd rather ask)
Post by: RobA on June 20, 2013, 01:30:41 PM
It depends on what you are using them for. For a filter with a critical cutoff frequency, it probably isn't good enough. For use as a decoupling cap, where you usually are going to be seeing 1µF caps, 10% is almost always going to be fine.
Post by: croquet hoop on June 20, 2013, 01:40:52 PM
I see. But for example, if I take C2 in this Big Muff schematic: http://www.kitrae.net/music/big_muff_guts.html#Circuit
It says both:  "Coupling cap/High pass filter with volume pot" ;D In this case I'd say that a lower tolerance cap would be fine, am I right?
Post by: Vallhagen on June 20, 2013, 01:53:12 PM
Quote from: croquet hoop on June 20, 2013, 01:40:52 PM
Yes you're right.
Post by: RobA on June 20, 2013, 02:02:50 PM
Nice page, I haven't seen it before.
Yep, the decoupling cap is going to form an HP filter with whatever the impedance is that follows. For the output cap, it's the volume pot paralleled with the input impedance of whatever follows. You can compute cutoff frequency using the formula,
F = 1.0/(2 π C R)
If you plug in the numbers from the Big Muff output using say, 1.0µF and 0.8µF, both would be OK for a guitar circuit (keeping in mind that the cutoff is where you have started to come up from the filter knocking out most of the signal so you really want the cutoff a couple of octaves lower than your lowest notes you are going to play).
The only place you might get in trouble with it is if you had a low input impedance pedal or amp coming right after the BMP.
Post by: croquet hoop on June 22, 2013, 01:36:01 AM
Thanks for the formula, this should be quite helpful.
Regarding my yellow 1 uF cap, I found it here while searching for info on etching faceplates: http://www.madbeanpedals.com/builds/reports/zpsdx/index.html
The sad part is that they are...
QuoteAVX box caps (no, you cannot get these any more)
Too bad. but at least the matter is settled. No more mystery.
