Projects => Build Reports => Topic started by: youngstownguitar on January 28, 2011, 01:43:46 AM
Title: Zombii Slambox
Post by: youngstownguitar on January 28, 2011, 01:43:46 AM
This is my first build that wasn't from a kit -it really highlighted my incompetence with this stuff.
Sounds AMAZING tho - madbean makes some awesome PCBs.
Thanks to everyone that answered my noob questions here and to runmikeyrun@DIYstomboxes for all the help.
Here it is next to a 808 I built from a ggg kit
(http://i640.photobucket.com/albums/uu130/surgerymixer/P1010986.jpg)
guts:
(http://i640.photobucket.com/albums/uu130/surgerymixer/P1020001.jpg)
here is a pic of how I cracked the enclosure by using a worn out drill bit that was better off in the trash:
(http://i640.photobucket.com/albums/uu130/surgerymixer/Photo2-1.jpg)
I think I may build the same exact pedal again just so I can try to do a better job at it.  I certanly couldnt do much worse.
Title: Re: Zombii Slambox
Post by: chromesphere on January 28, 2011, 02:41:53 AM
Hey man, looks good to me!  Not an easy build...
For what its worth, ive built over 30 pedals, and have had the odd one crack like yours.
These days, i use a 'step-bit' in my drill press. It's much kinder on the enclosure, as it drills out the hole 1 mm at a time.  Just wish i had of bought the drill press / step bit earlier...
Paul.
Post by: FuzzMonkey on January 28, 2011, 07:51:21 AM
Quotehere is a pic of how I cracked the enclosure by using a worn out drill bit that was better off in the trash
Yikes!
Post by: gtr2 on January 28, 2011, 01:41:05 PM
Food job on your build.
I've never seen an enclosure crack like that!  I like that you still used it instead of throwing it in the trash too.
Post by: youngstownguitar on January 28, 2011, 09:46:26 PM
Quote from: gtr2 on January 28, 2011, 01:41:05 PM
Yea I just got a piece of metal from lowe's for $0.30 and cut it to cover the hole I busted out.  Then I just used some JB weld to patch it up- cant really see it when the pedal is on the board unless you are looking for it.
There is a lot of similiar situations here:
http://www.diystompboxes.com/smfforum/index.php?topic=89213.0
Post by: chromesphere on February 01, 2011, 01:54:39 AM
It happened to me only once, on the side of the enclosure like youngstownguitars did.  I was using a 12mm drill bit with a handdrill into the side of the enclosure.  Drilled out ok to start off with, then the cutting spiral of the drill bit, kind a got stuck as it started tp come out the otherside.  The hole cracked, even the clamp couldnt hold it in place.  The enclosure went flying across the room. I was like this: :o
Like i said, dont use a hand drill anymore.  Drill press with a step bit is easier, safer, quicker, does a better job, etc etc.  For 100 bucks, its not worth the potential injuries.
PS: oh yeah, mine was a prepainted 1590bb box as well.
Paul.
