Echo Base w/ Tap Tempo
Started by madbean, January 09, 2011, 11:19:48 PM
I built this over several weeks, usually when I had a spare hour or so to devote. I used the PTAP tap tempo and it works really well. The switch is for the tails mod, but I don't see any reason to turn it off! Anyway, great project...fired up the first time.
thetrend77
LOVE it! Your wiring and enclosure designs are impeccable!
pauloman80
Quote from: thetrend77 on January 09, 2011, 11:22:54 PM
+1. Top notch, my friend.  That is a gorgeous build, inside and out.
Regards,
pauloman80
PaxWorks
How did you get that great ecth?
I'll tell ya how.
He's Madbean.
irmcdermott
is this a future 'bean project? or something you can post in the "Extra Projects"? That looks incredible and I'm very interested in building one!
Haberdasher
Wow you've really outdone yourself on this one bean.  Beautiful!
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
jackbart1960
#7
I need to build one of these bugga's. Brian what do you think of the over all sound of the box?
Peace. J.J.B.
irmcdermott
well, i just saw jkokura's Echo Base build report and saw it's the same board. Where do I go to buy the boards?
Haberdasher
irmcdermott
Yes, it's musicpcb.com. Taylor's work on that board in particular is superb. There are few projects I've even enjoyed half as much as this one.
I'll preempt the questions also - the ptap tap tempo addition is no longer available. Unfortunately there isn't a good, simple alternative available right now. So for those of you wanting to ask how the tap tempo can be added, it's not available any more. The closest thing is the taptation circuit found at diystompboxes. Although, last I heard the store there was sold out. Aron is likely getting more in, watch for it.
irmcdermott
could the MV-52 chip smallbear sells be worked in somehow?
Yes, the molten voltage chip is usable, but you'll likely have to work out the application part of it. Thanks for the reminder about that one, I'll have to look at the data sheet again. If I remember right, the MV chip is expensive.
irmcdermott
