Cheaper short electrolytics (for baby boards and other tight fits)
Started by midwayfair, October 15, 2012, 02:06:42 PM
Panasonic has two "low profile" series: The KA and KS series. The KA series is 7mm high (about the same as a chip in a socket). But the KS series is only 5mm high, and 4-6mm wide. The lead spacing is also "normal," and they're 7c each, so 1/3 the price of most other mini electrolytics. There's a newer KA series that's more expensive, so use the following part numbers:
25v, 5mm:
ECE-A1EKS100 -- 10uF
ECE-A1EKS4R7 -- 4.7uF
ECE-A1HKS2R2 -- 2.2uF
ECE-A1HKS010 -- 1uF
There's a 22uF and 47uF cap in this series, but it's only 16v. Fine for anything without a charge pump.
ECE-A1CKS220
ECE-A1CKS470
Best choice for the 22uF and 47uF caps (25v, 7mm):
ECE-A1EKA470
ECE-A1EKA220
And we're stuck with 16v for short 100uF caps:
ECE-A1CKA101 -- 100uF
Given that I recently had some trouble with 11mm caps in a 1590B (?!? there were pot covers), I think I'll be getting a bunch of these for the future.
EDIT: Nichicon 22uF, 25V: USW1E220MDD
saxoftenest
Nice! I'll have to update my project lists in Mouser with some of these.
I've been leaning heavily on the Nichicon UMW and UHC lines for short electros. They have a 5mm tall (but 8mm wide, so it's actually labeled "tubby" in my parts bin) 25v 100uF: UMW1E101MDD
9Lives
Om_Audio
Nice. I have a few 1590a builds in my future- this will come in handy- thanks.
C
Stomptown
Quote from: midwayfair on October 15, 2012, 02:06:42 PM
Do you know if there are any 5 or 7mm 220uF's available on mouser? I'm having trouble searching for them and would prefer the smaller ones for the Nautilus I'm building.
Edit: never mind, I found some 9mm that will work fine  ;D
aballen
Jon,
Thanks for this list, I'm restocking.  Would you happen to have a similar list for film and mica caps?  or MLCCs?
Quote from: aballen on February 02, 2013, 01:27:49 PM
Jon,
I don't buy mica, so I don't have any suggestions. My understanding is that there aren't small mica caps.
I usually get MLCCs at Tayda because most of the time they're cheaper. Brian's got plenty of suggestions in the build docs. Tayda's box caps are good, too. They're 5%,
