Sea Urchin problem..
Started by ckim715, February 25, 2012, 10:36:07 PM
ckim715
I'm going to swap it out for a 4558. Let me get back to you in a sec. Thanks, Brian
-Charlie
ckim715
I'm stil only reading 6.8 with the 4558.
-Charlie
ckim715
voltage on the 1n4001 is reading 6.6. Could it be the 33R resistor, or the diode?
-Charlie
Are you sure you did not use a 3k3 resistor? Or higher? The bands should be orange-orange-black.
ckim715
the resistor bands are orange orange black gold brown. The DMM, set at 200 ohms, is reading 33.4.
-Charlie
ckim715
I think it might be a bad resistor. But would this explain the delay not working after a few minutes? If it was a bad resistor from the get go, and I'm not getting enough voltage, wouldn't it not work at all?
-Charlie
ckim715
Then again, if it was a bad resistor, my DmM wouldn't show 33.3, would it?
-Charlie
Take the resistor out and put a jumper in its place to see if that solves the problem. If you are running the effect on a well regulated power supply or battery it's superfluous, anyway. And it that does not solve it, then it could be somewhere else down the line in the supply chain.
ckim715
I jumpered the 33R, and now the LM7805 is getting massively hot. Can't figure out what's going on now.
-Charlie
ckim715
I have a 330R, is that too much to try and sub the 33R with?
-Charlie
ckim715
It was the 33R. I replaced it with a 100R, now it's working fine. Thanks again, Brian.
-Charlie
I've been away for a couple days...
glad to see you got it working  :)
Josh
