More low end to Chunk Chunk
Started by jase, January 20, 2012, 05:50:52 AM
jase
Hi everyone/anyone, is there a way to get some more bass out of this pedal.
I love the way it sounds, it just needs more Ooomph to my ears.
Cheers
Had a fiddle with a tonestack calculator... You could try a lower value for C12... try 100n.  (Even down to 22n)  Let us know if that works!
jase
Cheers, I'll try that when I get some time. I like the  tone of the pedal and it's very articulate.
I tune very low ( A# Standard ) and don't won't to compromise the definitiion, a lot of pedals just sound muddy
but the chunk is nice, just needs a little kick in the butt is all!
jase
Is there a way to switch between several different values, like stock and two others?
How would I wire a switch for this, and could someone do a sketch so my simple mind can wrap itself
around it!
Many thanks in advance for any help.
Jase
On (Off) On DPDT (you can use an SPDT but this is probably easier for me to explain).
Middle 2 lugs, stick wires to your board with the lowest value cap you intend to use.
Other 2 sides stick whatever caps you want to add in parallel with it so say in the middle you have... 22nF, one side you could have 33nF for a combined value of 55nF and the other side a 100nF for 122nF.
Make sense?
jase
I'm a bit confused still, any chance of a diagram?
Sorry for being so daft....
Scruffie's idea is cool... you should hopefully get 3 bass response options from 'stock' to 'thunder' if you wired it like this...  Let us know if this works  :)
*edit: you can experiment with capacitor values, these are my suggestions*
jase
Brilliant! Thanks for the clarification, your diagram was just what I needed.
jase
Should it replace C11? That one seems to line up to the bass pot more....
C12  :)
jase
Ok, I've ordered the parts. I'll let you know how it goes when I've got it installed.
Thanks again for all he help.
looking forward to hear how you got along :)
Thomas_H
#12
Hi, I just happened to build a chunk chunk as well and trying it out I was also missing some low end.
I just tried the mentioned mod and just wanted to tell that it works great !
I was using  the switch with the following values: (because thats what I had lying around  ;)) )
168n
33n
47n
I also think that you could lower it down to 22nF - but thats a matter of taste anyhow.
I was very impressed by the fact that if did not harm the overall sound of the pedal.
Now looking to put it in a nice enclosure.
DIY-PCBs and projects:
Cool... thanks for the feedback Thomas!
Make sure you post a build report when you get done 8)
Bored
Quote from: Thomas_H on January 29, 2012, 11:52:36 AM
168n
33n
47n
Was it cap 11 (feeds 2 of the Bass pot lugs) or the above mentioned C12 (feeding the center lug of the Mid pot)
