Kingslayer for bass?
Started by thesameage, February 28, 2014, 03:02:39 AM
thesameage
Anyone using one on bass? What mods did you do?
Talked to Grindcustoms and he had a few suggestions to change the input cap, the low frequency cut off cap, and tone stack frequency response. Has anyone else built one just for bass?
Quote from: thesameage on February 28, 2014, 03:02:39 AM
Yep. sure did. used the mods he suggested, it has a permanent spot on my board. I built a limited run Grind Klone with a booster on it as a matter of fact.
thesameage
How would you describe the sound? Exactly what values did you use?
A very tight overdrive with great definition. Input cap was a 390n.
thesameage
Getting closer to building this-- boards should be available tomorrow. Still doing my homework, though.
So... can anyone tell me what the/which is the:
1) Input cap is, 2) the low frequency cutoff cap is, and 3) the tone stack frequency response? :)
Also looks like I should give the bass contour knob mod a go:
Bass contour knob
http://www.madbeanpedals.com/forum/index.php?topic=13353.0
If you read the instruction forum over at grind, he and I had this whole discussion  including which caps to switch. I don't remember it anymore, been a while.
thesameage
I think at minimum you can switch out the input cap... that's Rej's suggestion for the Chimera. There are a lot of other things that you can do though and when you change one thing, it changes others and you have to compensate-- that's why it's complicated, at least that's my understanding.
