First experiment with SMD
Started by marauder, October 06, 2013, 04:12:42 PM
marauder
Some SMD J201s mounted on 4x4 vero board, legs added, filed down as small as possible.
Holes drilled in a candle, surplus Envirotex from some enclosures poured in, and J201s drowned in it.
Leave a few days, crack the candle, wipe with some solvent, and paint.
A lot of work, but the J201s do only cost 13p each, and anything else is just surplus and essentially free.
And they do look like some 1960s mojo trannies,  TGP would lap them up.
That's hilarious. Worth the effort for faux mojo. Love it.
DutchMF
Now that is the true DIY spirit!! And they do look good.....
Paul
Tried selling 'em for 20 pounds each, yet? :)
kothoma
Great idea executed perfectly!
Do they have the same pinout as their counterparts?
gingataff
Bravo!
I'm so jealous that I didn't think of that.
Ettore_M
Genious and unbelievable are the words that came to my head right away! Well done! True DIY and really clever!   :)
And with the price of TH J201s going up, that's a pretty cool solution!  ;)
Nice job.
Hector
- Culturejam
GrindCustoms
Haha! That's one of the coolest thing i've seen! 8)
Have you tried measuring them for a phaser yet? Load up a jFet tester on a breadboard and tell us the results!
billstein
Quote from: jkokura on October 07, 2013, 05:13:12 AM
I was thinking exactly the same thing.
jighead81
That is so awesome, what did you use for the legs?
icecycle66
We've only used them in OD/Distortions so far, but yep, you can pair some up and do a phaser if you make enough of them ;)
The legs are the solid core wire I use stripped.
Jeez, that looks like a lot of work.
For some FET layout stuff, I am thinking of making boards that accept through-hole or SMT.  It's SO much easier to solder them onto the correctly sized pads on the board.  I don't think I'd have the patience for this.
